Cut and fitted each of the foam for the flap leading edge. Mixed up a batch of Aeropoxy Light, prepped the spar and installed them. Now once again, the biggest pain in aircraft construction raises it's ugly head, “waiting for the epoxy to cure”! Its part of the game but it is very frustrating. I could be doing so much more if I could touch it, handle it and work on it. But, it has to cure. I will be setting up a temporary work bench in the drive way tomorrow to shape the foam to the ribs. I want to be careful so I don't end up having to remove and replace a mistake. Patience!
cutting and fitting complete
Epoxied in place.
Waiting. And waiting, and waiting. Until tomorrow!
