It's 88 degrees and 80% humidity this morning and it is only 10:15am. It is going to be a hot muggy day. We spent just over an hour out in the garage and we are soaked. We did however, get the top trailing edge epoxied in place.
We had to make two jigs to hold the wing leading edge spar hig in the air to hold the trailing edge flat against the work table and install some stop blocks to keep the trailing edge back flush with the top cap strip. a few mixing sticks used as wedges and we were ready to mix and apply the epoxy.Now we have to wait 24 hrs for it to cure before we can move the wing back over and begin clean up and finish work. Too hot to work this AM.
Carroll marking the placement of the stiffeners so we don't apply epoxy there.
Bracingand wedges in place ready to epoxy.
Epoxy applied and waiting for curing. High humidity will make it take 24 hrs at least.
