RR3 Web Site
Date:  9-15-2018
Number of Hours:  2.50
Brief Description:  Leading edge complete
Even though it has been hot and unbearable in the garage the last few days, I spent a half hour here and there finishing the bottom leading edge. Everything is filled, sanded, varnished and primed on the bottom. We still have to varnish and prime the top leading edge. The varnish seals and hardens the spotting compound. We will take care of that once we flip the wing back over so we can complete the trailing edge epoxy work.
So, even though I have not kept up on the log as I should have, I am combining the little bit of sweaty daily work here and there over the last week in this entry. Everything looks nice and now it is off to work again as the temps here in Central Florida are going down into the lower 90's for a change along with lower humidity. If only my garage was insulated so the portable ac we have could keep up! Oh well.
Leading edge (Bottom) complete.
Ribs nicely blended into spar.
Staple holed filled, sanded and varnished.
