Brief Description: Only small things completed today.
installed the fuel tank side foam cushions and trimmed up the top cap strips on the ribs for trailing edge install. still some small fitting to do before install begins. we will wait for the adhesive to cure to install the tank and fittings before we begin on the trailing edge. We also set up the jig for the rear fuel tank fiiler. that will be slurried and then cut to a rough shape for final fitting and install. Its 9:30am and already 89 degrees outside. .
Tanks supports installed along with side cushions
relief fcuts for trailing edge.
Rear tank filler ready to slurry and cut out when cured.
