Spent the morning grinding epoxy from the ribs that will take Aileron and Flap hinge brackets.Cleaned up and epoxied the trailing edge in place and stapled in place.
The butt rib has not bee attached to the trailing edge yet. Once the tank location is verified and the Butt rib is epoxied in place, then the trailing edge will be epoxied to it. The trailing edge (top and bottom) will be completed after this is accomplished.
This wing will be completed much faster thatn the Left one!
