Shaping is 80 % complete on the Aileron. Discovered one bay of the aileron did not recieve enough epoxy to hold it in place while shaping. I shaped that bay as well as I could and re-epoxied it. Will have to wait until tomorrow to finish the aileron. I did notice the the loose bay core was slightly bowed from the tight fit. So, I used a straight edge and clamps to keep it aligned while the epoxy cures.
We decided to enclose the ends of the aileron and flap with foam to keep any critters form entering and making a home. So, we filled the gap to the edge of the end ribs with foam and will shape it and seal it before fiberglassing and covering.
