After completing install of the new Flap hinge brackets and drilling out the hinge points, we began to fit the control cable pulleys. Unfortunately, we discovered that the pulley brackets supplied with the kit are not what is called out in the plans.
The manual calls for a "dual bracket" for the up and down travel of the ailerons. What was supplied with the kit was a qty of four brackets identicle to the Flap pulley brackets.
WIth no addendum to the manual we are stymied. The brackets supplied do not line up correctly. Not sure if this is a change from the factory with a non updated manual or an oversight/error on the factory's part. Waiting to here from them now. Not holding out for a reply though. They rarely answer questions we submitt. Better to see if the community has an answer first. So, on to other tasks for now.
Hinges and brackets cinished
Call out per the plans ...
Items supplied. Big difference and don't line up as stated in the plans
