Brief Description: Prepping Ribs for Fuel Tank install
Today we set the repaired rib in place and marked its proper location, ground out the epoxy where the tank supports lay and epoxied to the rib and cut the tank supports to fit. There will be quite a bit of trimming once the ribs are epoxied into their final location but we can make our preliminary fitting of the tank in the left wing now. Tomorrow will be for fitting and trimming.
