Fitted the left wing to set final rib, butt rib and fuel tank. Unfortunately, we discovered that I made an error setting rib # 8. It become apparent that it was not right when we measured out the placement of the Butt Rib. It was 1/4" inch off center.
So, we have to grind out the Hysol on that rib and set it to the correct dimension and re-epoxy in place. We will be able to accomplish what we wanted to do today when that is done. This sets us back at least a week. Just goes to show that no matter how careful you try to be, mistakes can and do happen. Better to dicover them and correct them when found no matter how much work it takes to do so.
