RR3 Web Site
Date:  4-17-2016
Number of Hours:  1.75
Brief Description:  Continuation of Left Wng Rebuild
Spent the good part of 2 hrs grinding epoxy from the forward end of the wing ribs to accept the nose rib reinforcment plates. Only cleaned 4 ribs with 4 remaining. Close to 2 hours of holding a Dremel tool in your hand leaves you with no feeling in the hand. I will finish 1 or 2 each day this coming week.
Carroll has been prefitting the tail surfaces to the fuselage and reaming all of the hinge points.
