Worked on the prototype for the position lights. Worked on the resistor board and placement. Drilled holes for the board mounts and cut out area where the heat sink will be below the base. I can see a lot of mods to make with the items I was able to find locally. I am sure I will be going through more of the components. There are always be errors made that will damage something until you get it right.
Rough board prototype
LED's and heat sinks
Modified bases. might have to have more printed if I mess these up.. May rework Cad and reprint anyway
