Cut out template and wingtip sheet metal. Did some bending and drilled and clecoed all the holes. Looks nice. I will be curling the outer top skin to folow the tube profile edge. It will be a tough job getting the tip to taper down. I will need to take my time when I get to that point.
I also epoxied the trailing edge stiffeners together in preperation for install.
