RR3 Web Site
Date:  2-22-2019
Number of Hours:  1.75
Brief Description:  Beginning of finish work on Rt aileron & flap.
Began finish work on the flap and aileron this morning. Started with the hinge slots now that the fiberglass work has cured. It gets a little sloppy in those slots, with the epoxy. So, it took several thin costs of spotting compound after sanding as much a s possible and avoiding the fibers.
Now the slot sides are smooth and the bottom of the slots are curing. It will take another thin coat on the bottoms and we can continue with the filling and compounding of the rib to leading edge work. Once that is finished, we can work on blending in the trailing edges to the ribs. Hopefully, we can get this completed in about a week off and on. the compound takes a while to cure. So, it is start and stop for several days until done.
Second coat of spotting compound
Skim coat waiting to be sanded
ready to apply to the bottom of the slots.
