Shaped the trailing edge of the aileron ribs to accept the metal trailing edge. That's all folks! Need to cut out the slots on the trailing edge and fit them . Then it will be off to the races with the Hysol and the cross members and foam leading edges.
Cutting these is diffcult .
shaping these with a sanding block is just as bad.
