Finished the epoxy work on the non hinge areas of the rib to spar areas. Now I have to wait three hours for the Hysol to flash before I can smooth it all out. Hysol is a messy job. I know, I've said it before but, It is! It is very time consuming and a real pain to clean up. Application is a pain as well. You have to use a zip lock to do a good job. Even then it is still very messy. Getting a good fillet is the hardest and most important part. You get the best strength with a good fillet to avoid high stress zones in a structural application. Smoothing it out after it flashes is the only time you can get it right.
While I was waiting (I still am at this writing), I rough cut the right wing flap stop. I will wait to finish it once I have the hinge brackets riveted in place and the hinges aligned and epoxied and riveted before I mark its final shape and position. Once I get everything in place and fixed I can clamp the flap in the closed position and mark clamp and drill the stop. I have not riveted the left flap stop yet. We will do that once we get the wings hung on the airframe.
Remainder of the non hinge Hysol Epoxy complete.
Waiting on the Hysol to flash for smoothing.
Right Flap stop rough cut. Time to finish shaping.
