Carroll and I rechecked each piece and found a few that needed tweaking and we re-sanded them to fit as perfect as possible. We also cleaned as best we could all the dust that had settled overnight. Thank God for fine particle filters available for the shop vac.
We mixed up our epoxy and were able to get each piece epoxied in place then I realized that I will have to turn the wing over to finish the epoxy work tomorrow. Since we could not get to the opposite side to apply a nice filet on the upper end, after the epoxy is cured, we will turn the wing over and complete the epoxy work. I also have to enlarge the hinge bracket slots once everything has cured and check the fit of each bracket to ensure proper clearance. That will have to wait.
