After careful fitting and pep, the bottom trailing edge work went rather well. With only the one slight bow to correct, that is all that is left to do on this part.
The bottom trailing edge is finished. Even applied the rest of the varnish on the bottom. Now we have to build some small simple jigs to hold the wind flat against the table to clamp and epoxy the top trailing edge in place. Once the epoxy is cured, we can flip the wing over and finsh the top of the trailing edge, cut our hinge bracket slots and install the stifeners for the trailing edge re-inforcement.
Finsh work done
Varnished to strengthen and protect the spotting compound
Now to get to work on the top trailing edge epoxy work.
