RR3 Web Site
Date:  9-15-2018
Number of Hours:  1.30
FInished the bottom leading edge today. All shaping, filling and finish sanding is done and thin coat of primmer applied after the finish sanding with 400 grit around the spar and ribs. applied first coat of varnish on the front part of the rib cap strips as well.
FInsihed blending the ribs to the spar and primed
Blended rib to spar
Blended rib to spar
First varnished coat
