RR3 Web Site
Date:  9-8-2018
Brief Description:  top finish work complete
Completed finish work on the top leading edge. It took another thin coat of spotting compound and 400 grit sandpaper to get everything smooth. The top of the ribs are now smooth and ready for a varnish coat. That will have to wait until the bottom is finished. Carroll will be coming by later today to help flip the wing over on its back so we can begin work on the bottom trailing and leading edges. We will remove the remaining attach bracket rivets tomorrow and get both of them ready to re-install before we install the trailing edge re-reinforcements and final epoxy of all joints. Then it will be onto the final flap and aileron.
Rib blending done
Rib blending done
All finished snading.
Ready to be flipped and process repeated.
