Finished the tank hold down strap install rechecked tank fit and completed running and installing the connector for position light. the connector will make it easier to disconect the position lights if the need arises to remove the wingtips. weatherporrf connectors of course (1.5gm) Also epoxied the bottom tank supports in place.
Tank hold down strap installed
Wing tip position light wiring and connector installed
