RR3 Web Site
Date:  7-24-2018
Number of Hours:  2.50
Brief Description:  Finish install of L. wing tank
After several faile attempts to come up with a tank hold down system, simplicity turned out to be the best. We simply added a filler plate behind the installed brackets and secured the filler plate and tapped the hold down strap fo 10/32 machine screw. worked out great. no more fear of the silicone adhesive letting go of the tank. (Mfr's solution) it weighs 3 oz. Now all we have to do is install the fuel port and the quick drain and the tank is complete.
Filler plate installed behind bracket
Filler plate
Filler plate
Tank Hold down complete.
