RR3 Web Site
Date:  3-27-2018
Number of Hours:  1.75
Brief Description:  On to other things for a day
Had some honey do's today, so I spent time on some other nit picky things on the wings to keep up on the completion. I need to fill the gap between the rear spar and the rear of the tank. SO, I tried once more to use some plastic sheeting and spray foam to create a template to cut the foam required into the proper shape. Once again, it did not work out. the center does not cure because of the plastic. It keeps the center from curing and it remains a gooey mess. So, I whipped up some bondo, inserted more sheet plastic and filled the area with it. Tomorrow when it is nice and cured solid(don't want ti clog up my blade) I will use my band saw and slice it. I can then use it to create wood templates to cut the foam into the shape of the gap. I also epoxied the foam scraps into a long enough chain to fill the entire area. I also test fitted the Aileron so far so good.
@nd try at using foam to create a template
Scrap foam epoxied together.
Aileron installed.
Aileron installed.
