It's been a tiresome day today. We started the blending process on the left wing while we wait a couple of more days for the Aeropoxy to fully cure. The lightweight body filler should be easy but, the first application was a bust before we even got to apply it. I used too much hardener for the heat we had today and it was hard before I walked around to apply it. Second attempt was much better and now we have all but the last two ribs and four false ribs to blend. We also began filling in all the staple indentations with spot putty. There will be lots of sanding tomorrow. I am sure there will be lots of spot fills as well.
