RR3 Web Site
Date:  3-11-2017
Number of Hours:  2.10
Brief Description:  AILERON HINGES
After recuperating from a bad flu (or something), we finally have gotten back to work on the wings. Carroll is off with his instructor making holes in the sky. So, I decided to get the epoxy ground out of the rear portion of the hinge bracket areas on the wing ribs this morning. I have to say that the Aeropoxy is one hard epoxy. But, its done and the brackets and the aileron construction table is in place.
There is a slight warp to the table now that it is clamped into place. So, I will have to pick up a 6 foot piece of angle to attach to the bottom and pull it out warp. We can't build ailerons on a warped table. It is nice to get back to work on it.
AILERON BUILD PREPERATION
HINGE BRACKETS
HINGE BRACKETS
WINGTIP BRACKETS
WINGTIP BRACKETS
