RR3 Web Site
Date:  6-22-2016
Number of Hours:  1.25
Brief Description:  Replacement Doubler straps
Finished the layout and pattern for the Doubler straps. I made five copies of the pattern, Just in case! We only need four but you never know, and of course, I had a brain fart and realized we need a total of eight. Four for each wing. Top and bottom of each spar attach point!
I have been searching for a Sheet metal shop to bead blast the wing strut attach fitting we had to remove from the bad spar and also to cut out the doubler straps. No luck on a shop that could cut the straps out (at least at a reasonable cost).
New layou of replacement doublers
