RR3 Web Site
Date:  1-3-2016
Number of Hours:  2.50
Brief Description:  Left gear
Left gear is almost complete. Waiting for the rubber coating on the wheel halves to cure. Discovered the innertube valve stem is quite long. It interferes with the axle nut. We will have to fabricate a rubber washer to sit between the inner wheel and the innertube. We need to shorten its extension by 1/2".
Test fitting for shim requirements
installing innertube in tire. Tough job!
