Swinnys 4 Place Bush Explorer
Date:  2-2-2015
Number of Hours:  6.00
Brief Description:  Oil Cooler ducting & sealing engine baffles
After modifying the oil cooler box that I had spent so many hours on back in December, into something a little more simple, I the fitted a new piece of 5" scat tube between the rear left baffle plate and what remained of my oil cooler box.
I then spent time carefully using the heat resistant red silicone rubber sealant to fill the minor gaps between the engine baffles and the engine.
This is just about the completion of the engine & baffles installation.
Modified Oil Cooler duct
Sealing engine baffle gaps
Sealing more engine baffle gaps
