Today I finished the wing cradles then cleaned and primed the aileron parts before then tackling the wing tip fitting.
Had always planned the make up drooped wing tips similat to the STOL tips you sometimes see on C180's & 185's , however time is in short supply , so decided to run with those provided in the kit.
I may still revisit this issue sometime in the future.
