Swinnys 4 Place Bush Explorer
BushCaddy L164
Assembly of the spars
Probably more time spent on the computer in recent days investigating wing 'g' loadings and emails with other builders.
Not at all happy with the lack of support from the kit supplier.
Finished etch priming a number of the wing parts and started on the spar splice plates.
Root ends of the two rear spars
Spar splice plate.
The Flap crank that has to be modified
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
