Swinnys 4 Place Bush Explorer
BushCaddy L164
Fairings
2-8-2015
Leg Fairings and Nose cone fitting
I completed the fabrication of the gear leg fairings and then started the assembly of the nose cone and prop backing plates.
21 Plate nuts and then etch priming.
Completed right gear fairing
Plate nuts installed on the prop bacing plates
Backing plates etch primed
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
