Swinnys 4 Place Bush Explorer
BushCaddy L164
Fairings
7-6-2014
Wing to fuselage gap fairing
This took many more hours than I had anticipated.
I used the off cut sections of the leading & trailing edge skins to form the front and back areas and the flat strips supplied for this location.
After marking and drilling the pilot holes, I then used nut serts to provide the screw fastener anchor nuts.
Leading edge right wing
Trailing edge right wing
Wing bottom gap cover
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
