I decided to combine the PTT inputs from both Pilot & Co Pilot through the connector to the Trim Priority relay box for ease of making the connection and elimination of the need to have a separate connector. This also had an added advantage of eliminating an extra ground wire.
I tested the circuits & no smoke appeared, so very satisfied with the result
When installed, the relay box will be fixed in place on the cross member below the front seats & wires run up to the various connections behind the panel.
Trim Priority relay box finished.
Enough wire to be run in one length to the appropriate connection.
