Swinnys 4 Place Bush Explorer
BushCaddy L164
Dynon Remote Compass mounting
I decided to mount the Dynon remote compass in the upper fuselage just aft of the number one bulkhead.
To get the required angle to match the angle of the dynon unit in the dashboard required a bit of fiddling around with the laser level.
I used brass screws and soft aluminium hinge wire in the mouning hardware to avoid any magnetic influence.
Much easier doing this work now before joining the Cabin & Fuse together.
K.I.S.S.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
