I connected the 14v power to the master relay and powered up the panel today after installing the cigarette lighter to the panel (not for lighting smokes, just for power to the IPad later), and was somewhat dissapointed to find that the NAT audio panel did not light up as I thought it should.
Turned out that the Audio panel model that I had acquired has 28v lighting so will need the PCB with the wheat grain lights replaced with a 14v card.
Started to test the Mic and Phone jacks and found some problems, so ended up removing the audio panel and wiring harnesses and took them off to the Avionics shop to ask for help.
Turned out that I had made a few mistakes in the wire connections.
Power applied & the lights came on!
Panel fairly well completed.
The Dashboard eye brow mould made out of 3/8 tube is very pleasing.
