Swinnys 4 Place Bush Explorer
Date:  11-13-2014
Number of Hours:  8.00
Brief Description:  Top left cowl
After completing the exhaust opening in the lower cowl area, I then moved up to the left top opening cowl.
I again used the stiff card board as a template, then transferred this onto the aluminium.
These cowls will need to be put through a set of rollers to form the curve as there is too much pressure required to hold them in position.
I will track down a set of rollers when I doo the other side.
Top left card board template
Top left clecoed
Top left clecoed
Starting to give a good shape!
Copyright © 2001-2021 Matronics. All Rights Reserved.
