Brief Description: Positioned the right wing fuel tank for the first
Once again the fuel tank does not have the same top skin curvature as the wing ribs.
What idiot made these?
Nearly half an inch gap between the top wing skin and the tank top skin about 2/3 rds of the way towards the rear of the tank on the outboard side and slightly better at the inboard wing rib.
Not surprised to learn that the current Bushcaddy owner has called it quits without advising owner / builders of these kits and has claimed he has moved the outfit to China
If it is only a rumour, or if it is true, wouldn't you think the silly prick would at least post the info on his web site? What a tosser.
Right side fuel tank positioned for marking the securing screw holes.
