Brief Description: Fitting internal linings to left side of cabin
Using the small pieces of angle cut offs supplied, the linings are attached to the cabin frame structure using rivets and then screws & washers (not supplied)!!
Front left side
Attach bracket on frame
Attach bracket onto section of the folded lining formed from alclad and covered with the covering.
