Swinnys 4 Place Bush Explorer
BushCaddy L164
Flap & Aileron push tube fitting in left wing.
Finished fitting the push tube rod ends and then bent the bellcrank to the correct angle for the connection to the flap & aileron.
Spent a number of hours doing the final deburring on the ribs & stringers, and then vacuumed out the wing.
Duoble checked all bolts for correct torque & torque seal applied.
The first wing is now ready for final closure.
Aileron bellcrank & push tube assembly
Flap bellcrank & push tube assembly
Bellcrank end bent to correct angle.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
