Brief Description: Mounting Bellcrank & Supports in aft Fuselage
This morning I started on the second bellcrank installation in the aft fuselage . Used the laser level again to double check alignment of pushrod holes, marked them, then used a unibit to form the holes in the lower cross members of the fuselage frames.
Now all I have to do is work out how to support the bellcrank!
Using the Laser level to check alignment of pushrod holes on centreline.
Pushrod holes formed through lower fuselage frames on centreline.
