Brief Description: Fabrication of two bellcranks of same dimensions.
Having decided to offset the Elevator pushrod to make better use of the cargo area, I ordered two bellcrank bearings (BC5W11) and 4 AN490HT8P Threaded Rod Ends from Spruce.
I used 3/16 Aluminium tp make up the bellcrank arms and other pieces of scrap aluminium for the spacers.
Fabrication of 2 bellcranks.
The bellcrank components before etch priming and riveting
