Started to worry a little today when I installed the tail wheel spring for the final time, two reasons, the spring leaf widths supplied are a fair bit narrower than the Alaskan Bushwheel tailwheel connection that I had ordered with the kit, so there is a miss match of parts by the kit supplier and also because after bolting the spring leaves onto the mounting plate, the whole arrangement looks and feels under strength. No doubt time will tell. I may have to brush up on my landings a little, as in the RV I rarely do 'Wheelies' and most times drag the tail wheel on first.
