Swinnys 4 Place Bush Explorer
Date:  5-17-2010
Number of Hours:  20.00
Manual Reference:  Page 45
Brief Description:  Landing gear mounting brackets
During the past couple of days I have been working on the mounting brackets in conjunction with fitting the lower cabin skins.
Contrary to the steps detailed in the manual, I feel it is much easier to mark out, drill and fit these brackets before fitting all of the bottom skins.
Lining up and clamping ready for drilling was a piece of cake.
After satisfying myself of the correct locations and double checking every measurment, I started with 3/32 holes and worked up to the final hole size in 3 stages of drilling.
If the cabin bottom skins had been hard fixed prior to fitting the undercariage brackets, lining up, drilling, deburring and would all be far more difficult.
Rear main landing gear brackets
Right side rear bracket
Positioning of the front right wing strut
