Not much done over last couple of days. I used the right side skin as a template and marked all holes on the left side, positioned the skin in place with clamps then drilled. While skin was in place I drilled the hole for an AN3-? Bolt to go through the seat belt attach bracket. I had forgotten to do this on the right side, so repositioned the right side skin and did the same on that side.
