Swinnys 4 Place Bush Explorer
BushCaddy L164
Still working on engine install.
Lock wired the prop spacer and fitted the Alt Induction Air control cable.
I then completed the baffle sealing rubber around the tops of the baffles.
Prop spacer bolts lock wired
Induction Alternate Air door control cable
Alt Air Control Cable thru to cabin.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
