Swinnys 4 Place Bush Explorer
BushCaddy L164
Fitting the CamlocS
Before removing the cowls once again, I moved back over to the left side to install the cowl closing fasteners.
I decided to use Stainless Steel 2600 Camlocs on the left side top cowl, as this cowl is not opened as often as the right side.
Fitting the receptacles acurately is very time consuming, however the end result is pleasing.
These studs can be easily removed when final painting of the cowl is done, then replaced to give a classy finish.
Left side finished
Camlocs look tidy !
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
