Swinnys 4 Place Bush Explorer
BushCaddy L164
Fitting wing stringers.
Finished placing and riveting the stringers today.
Marked the centre lines on all ribs.
Drilled and clekoed the trailing edge ribs into place.
Before riveting the flush rivets holding the stringers, measured the diagonals of the wing to ensure it was square and clamped to the table.
The most difficult work in installing the stringers is in the dimpling of the rib / stringer joints so that the avex csk rivets are flush.
All stringers placed
3/32 flush (csk) rivets used at rib cutouts
Rib 7 with fore & aft reinforing angles attached.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
