Swinnys 4 Place Bush Explorer
BushCaddy L164
Still fidling with the left wing.
Before removing the wing to the cradles, thought I had better finish off some of the final fittings.
Had to enlarge the holes a bit more in the inboard wing rib so as to allow the easy removal replacement of the fuel tank.
Then went back to the wing tip and started to make up a balsa wood mould for the strobe & nave light fitting.
Feul tank fittings installed.
Fuel drain & rear tank pickup fittings.
Fitting the nav light to wing tip.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
