The silly season is here again and I'm a little bit in need of some pointers on how to install the bungee loops.
4 loops were supplied with the kit and it looks like a monumental task to get these into place without killing myself.
All or any suggestions would be welcome.
Merry Xmas y'all
To overcome the problem I had discovered back on Nov. 11, when fitting the Alaskan Bushwheel tail wheel for the final time, I folded up a copper shim spacer so that the Univair tail spring (1 &1/2 inch wide) that was supplied by the kit manufacturer, could be snuggly matched into the casting (1 & 3/4 inch wide) of the tail wheel. It was only after doing this that I discovered that Spruce supplies part number 06-00810 (ABI-3243-01) which is made just for this purpose for about $50.00.
Just another example of the poor quality control of the parts supplied by Bushcaddy. I didn't waste my time complaining or demanding the correct part be supplied because past experience tells me it would be a waste of my time. The bit about Builder support on their web site is untrue and needs to be corrected.
Alaskan Bushwheels Tailwheel bolted on
Landing Gear Legs bolted into place
The 3200 tail wheel assembly now matched to the spring.
