Spent most of the day drilling the holes to mate the cabin and fuselage. Found that the side skins along the lower edge at the fuselage on both sides are not in alignment with the fuselage skins and will need to be reinforced with a cover stip on both sides.
Thinking that I may have made a mistake in the fuselage setup, I double checked the 2 deg lean back on the number one bulkhead in the fuselage and also the vertival alignment of the rear cabin bulkhead and found these to be correct, so that can only leave that the side skins were supplied cut to the wrong angle along the lower fuselage area or along the rear door frame alignment.
In any event must move on so decided to make up splicing plate reinforcement strips. Stay tuned....
