Swinnys 4 Place Bush Explorer
BushCaddy L164
Fuel lines final install
As I tightened each fuel line fitting for the final time I applied torque seal to confirm that this fitting no longer needs touching (hopefully).
Also completed the fuel pump electrical connections plus the fuel computer sender wiring connections
Torque Seal applied
Fuel selector lever engraved
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
